Latest post Fri, Jun 23 2006 7:12 PM by rfmeredith. 2 replies.
Page 1 of 1 (3 items)
Sort Posts: Previous Next
  • Thu, Jun 22 2006 5:59 PM
    • lesterp
    • Not Ranked
    • Joined on Thu, Oct 13 2005
    • Posts 28
    • Points 370
    RE. A success! HD DNxHD sequence to SD DVD story
    In reference to this post:
    http://www.avid.com/exchange/forums/53103/ShowPost.aspx
    As far as specific DNxHD codec settings, is it correct to choose:
    Video
    Depth: Millions of Colors+
    Quality: Best
    Frame rate: 29.97 (origional source prior to transcode was 60i)
    Audio
    Format: Uncompressed
    Sample rate: 48kHz
    Sample size: 16
    Channels: 2
    Prepare for Internet Streaming
    uncheck this
    Just want to clarify for best possible end result.
  • Fri, Jun 23 2006 6:49 PM In reply to
    • lesterp
    • Not Ranked
    • Posts 28
    • Points 370
    Re: RE. A success! HD DNxHD sequence to SD DVD story
    Below is the origional post:
    After much experimenting and deadends, we have a very succesfull path to an NTSC SD DVD from a DNxHD sequence.
    Export as a QT Movie (not reference) 1920x1080 DNxHD codec, top field, RGB (this takes about 10 minutes per minute of finished footage) and does make a very big file.
    Encode in Procoder 2 as a Non-interlaced source, lower or upper field M2v and Wave file.
    Author with your favorite authoring program (we used DVD-Lab Pro).
    The result is sharp, with great color and smooth motion.
    We're still trying to see if we can use a QT reference file but those experiments are still on-going.
  • Fri, Jun 23 2006 7:12 PM In reply to
    I believe there is some DNxHD>DVD info buried deep in these also:
    http://www.avid.com/exchange/forums/thread/92476.aspx
    http://www.avid.com/exchange/forums/thread/96889.aspx
    if possible, stick with QT Ref instead of the huge movie file.
    MC 2.8.1 Dell 670, Dual Xeon 3.6 GHz, Win XP SP2, 3GB RAM (6x512) QT 7.2, nVidia Quadro FX3500/256MB, 8x500GB RAID 5 controlled by 3Ware 9650SE-8LPML in... [view my complete system specs]
