http://www.AvidUserGroup.NL fcp2avid "The Technology Is Not Guilty" - Nicolas Philibert quoted in "Documentary in the digital age" by Maxine Baker (2006)
I never use admin, but always a poweruser with all the rights. You could try to change the admin name you have. On the other hand I would be very surpriced if this is causing your troubles.
Regards,
jknikman: I never use admin, but always a poweruser with all the rights. You could try to change the admin name you have. On the other hand I would be very surpriced if this is causing your troubles.Regards,
The conclusion I draw from that is quite simple. Either your Mojo needs a firmware "pimp slap" or your mojo is bad.
To slap the mojo, connect to a sytem with an older version and it will prompt to update (downgrade) the software- or downgrade your existing AXP install then perform this step. Then go back to your system, or re-install your newer version, and it will again prompt you to update (upgrade) the firmware.
If this doesn't work, I'd pick up the phone and call after a replacement, normal functioning mojo's aren't supposed to have this issue.
JDS
Doc Avid:The conclusion I draw from that is quite simple. Either your Mojo needs a firmware "pimp slap" or your mojo is bad. To slap the mojo, connect to a sytem with an older version and it will prompt to update (downgrade) the software- or downgrade your existing AXP install then perform this step. Then go back to your system, or re-install your newer version, and it will again prompt you to update (upgrade) the firmware. If this doesn't work, I'd pick up the phone and call after a replacement, normal functioning mojo's aren't supposed to have this issue. JDS
Avid Technology, Inc. brands: Digidesign | M-Audio | Sibelius | Pinnacle Systems | Sundance Digital | Softimage
© Copyright 2000-2008 Avid Technology, Inc. All Rights Reserved — Legal Notices | Terms of Use | Privacy Policy | RSS Feeds | Site Map
