Latest post Fri, Jul 20 2007 3:56 PM by camoscato. 6 replies.
Page 1 of 1 (7 items)
Sort Posts: Previous Next
  • Thu, Jul 19 2007 3:56 PM
    • nasosan
    • Not Ranked
    • Joined on Thu, Jul 19 2007
    • altare (savona) italy
    • Posts 4
    • Points 50
    how to make dvd from mov file.. freeeware..
    hi, i have a mov file maked whit avid free dv, i have nero vision express 6, but when i try to create my dvd, i put my mov file into nero and nero make error.. the file is not compliant...(or similar)...
    i use nero more time, whitout error.. but not whit mov file... (divx, xvid, avi, mpeg2....)
    i search a prg to convert mov file to mpg2 or avi.. but nothing work.... or is shareware...
    there are a solution freeware?
    thank's
    http://www.nasosan.altervista.org http://www.nasosansoft.com
  • Thu, Jul 19 2007 7:04 PM In reply to
    • camoscato
    • Top 10 Contributor
    • Joined on Thu, Oct 13 2005
    • London
    • Posts 4,187
    • Points 50,160
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: MCA PC
      Moderator: Meridien
    Re: how to make dvd from mov file.. freeeware..
    Nerovision Express should be able to convert the mov file.  If you can tell us more about the settings you used when exporting from FreeDV, we might be able to figure out why it is not working.
    A Google search for freeware mov to mpeg2 suggests there may be many freeware programs that will convert mov to MPEG2.
    good luck,
    Carl
    There is no such thing as a video emergency. My Demo Website
  • Thu, Jul 19 2007 8:37 PM In reply to
    • nasosan
    • Not Ranked
    • Posts 4
    • Points 50
    thanks for the reply.
    the setting are default for quick time.. nothing is modified from the default.. but in this moment i cannot read it... tommorrow if i have help i comunicate you.
    for convert.. yes.. more and more "download freeware"... but all are shareware or demo...
    i have test quick time pro (i have buy a license.. but i not remember to have it.... :( ;) ) but the computer it now convert the file to avi...
    tomorrow i have a result.. and i try to make dvd whit nero and file avi....
    ps
    but is not possible to ovverride the limit of 2gb for avi file? whit ntfs i dont know nothing (avid only) can have this limit.... pinnacle, premiere, nero... windows movie maker... or other software for editing video... (donate whit hardware... nothing to paragonate to avid.. ;) )
  • Thu, Jul 19 2007 10:34 PM In reply to
    • Rob Stowell
    • Top 150 Contributor
    • Christchurch, New Zealand
    • Posts 331
    • Points 3,615
    I've got Nero too, and it doesn't like .movs. There's a freeware utility called "super" that encodes most formats. I've used that to make dvds from free dv quicktimes (you need to play with the free dv export settings- I've successfully exported using the (pal for me) DV options, and the avid codec. "Super" can be a little buggy- but it does make reasonable dvd files (mpeg2 or direct to vob).
    hp xw3200 1 gig ram 160gig + 200 gig sata video storage, x-pro 4.6 [view my complete system specs]
    kia ora- Rob
  • Fri, Jul 20 2007 7:04 AM In reply to
    • nasosan
    • Not Ranked
    • Posts 4
    • Points 50
    i have found super, but i dont found the link for download... in the page, are more link.. but where is write download.. dosent work.. or connect to other page, whit more text and link.. but not download file..
    you can give me the direct link for download?
    (i not see the result whit quick time pro at this time... )
  • Fri, Jul 20 2007 2:19 PM In reply to
    • nasosan
    • Not Ranked
    • Posts 4
    • Points 50
    export quick time format..but whit options set?
    hi, i have this problem...
    i export my video in qt format. but whit option? i set 320x xxx and dv-pal (compress format).. but the quality on my pc is best.. on dvd is low quality... i use nero for make dvd from qt file...
    in this moment i try to export to qt file, whit 768x5xx (i don't remember) and dv-pal other set to default...
    my nero epress 6. dosen't make dvd from mov file (in the first case qt file 320x xxx )
    everyone have a suggestion... possible freeware.. thanks
  • Fri, Jul 20 2007 3:56 PM In reply to
    • camoscato
    • London
    • Posts 4,187
    • Points 50,160
      Moderator: MCA PC
      Moderator: Meridien
    Re: export quick time format..but whit options set?
    Take a look at How to DVD, which will help you figure out the settings you need to get a good DVD.
    good luck,
    Carl
