Latest post Wed, Dec 14 2005 9:51 PM by Edit Monkey. 6 replies.
Page 1 of 1 (7 items)
Sort Posts: Previous Next
  • Fri, Dec 9 2005 9:46 PM
    Resize / Blowup Dv Footage
    Hello, I'm working on a low-budget 16x9 short film in Media Composer that was shot on DV, and the director and I are unhappy with the framing of many shots. In some extremely poor framing circumstances i've applied a 3d warp and just scaled the image.
    My question is; I'd like to do major resizing on many shots and there is an obvious loss of quality apparent (even at the 10:1 rez im working at), so im wondering if there is a way for me to keep the resolution decent and adjust the frame/push in on the shots?
    Thanks.
  • Fri, Dec 9 2005 11:43 PM In reply to
    • BLKDOG
    • Top 10 Contributor
    • Joined on Thu, Oct 13 2005
    • Lansing, MI
    • Posts 13,761
    • Points 174,395
    • Avid Employee
    Re: Resize / Blowup Dv Footage
    There is no easy solution to this as you will lose resolution when you blow up the shot. However, in the film caategory in your effects pallette, there should be an effect called blowup that is much better at scaling than 3D warp is. You might try that.
    Project Manager, Avid Professional Services Group
    FCP2Avid
  • Sat, Dec 10 2005 12:19 AM In reply to
    Thanks BLKDOG, I'll try the blowup effect.
  • Sun, Dec 11 2005 9:27 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,520
    Is the "blowup FX" action technically different to the "3D warp FX" ?
    What implies "much better" at scaling ?
    Thanks for answer BLKDOG !
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
    "out of difficulty comes performance"
    ______________________________
     Web site : www.audiacom.com
  • Mon, Dec 12 2005 4:08 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,761
    • Points 174,395
    • Avid Employee
    It actually is a lot better. I don't think it does anything special really, I think it's just that the 3D warp is really crappy.
    FCP2Avid
  • Mon, Dec 12 2005 8:28 AM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,520
    3D wrap crappy, oh yes !!!
    Thx for answer BLKDOG
    sep
  • Wed, Dec 14 2005 9:51 PM In reply to
    • Edit Monkey
    • Not Ranked
    • Phoenix, AZ
    • Posts 24
    • Points 310
    derek,
    I use the re-size effect to enlarge images. If you're working in a letterbox, you'll have to apply a 16:9 mask over the top to retain the aspect ratio. When you enter the 3d fx tool, for some technical reason I can't explain, you'll lose resolution more so than if you stay in the 2d fx mode.
    Also, 10:1 will exaggerate the loss of resolution because it's so pixelated to begin with. I think you'll see less degradation if you redig at 2:1 or 1:1.
    Avid Symphony 4.8 Mac OSX 10.2.4. Dual 1.2 GHz G4. 1 Gb RAM. Avid MC 1000XL. Mac OS9 9.0.867 GHz G3. 512 RAM [view my complete system specs]
    ~jd. "If there's a bustle in your hedgerow, don't be alarmed now, it's just a spring clean for the May Queen."
