Latest post Sun, Feb 3 2008 7:05 PM by camoscato. 1 replies.
Page 1 of 1 (2 items)
Sort Posts: Previous Next
  • Sun, Feb 3 2008 6:38 PM
    • Spaantje
    • Not Ranked
    • Joined on Sun, Feb 3 2008
    • Posts 1
    • Points 15
    "No Audio Cards" Asus P5Kc, Avid Xpress Pro (5.8)
    Hello,
    I have a Asus P5Kc motherboard with onboard audio card. Everything is working on my comp, and latest drivers installed.
    But when i start avid it says "Can't find any audio cards in your system. You will not be able to play audio."
    Is there a fix for this?
    Thanks, Spaantje
  • Sun, Feb 3 2008 7:05 PM In reply to
    • camoscato
    • Top 10 Contributor
    • Joined on Thu, Oct 13 2005
    • London
    • Posts 4,653
    • Points 55,475
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: MCA PC
      Moderator: Meridien
    Re: "No Audio Cards" Asus P5Kc, Avid Xpress Pro (5.8)
    Lots of people have problems with onboard sound (I'd bet your sound is Realtek or Conexant).  The easiest fix is to get a Soundblaster Audigy 2 and install that.
    Depending on what version you're running, you might be able to use different drivers.  If you search the forums for "realtek" you will find a lot of information about this.
    good luck,
    Carl
    MC 3.0.5, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
    There is no such thing as a video emergency.  My Demo Website
