All pro. In the control room. In your home. When recording a hundred-piece orchestra or a solo guitar. Whatever shape your studio takes, wherever your music takes you, Pro Tools systems get you there. Creative, professional, and brilliantly designed to adapt.
The Industry
Your high-performance studio. Anywhere.
  Glamourous or DIY. Apartment or spare room. Professional studios can take any form, anywhere. And with a Pro Tools system, you can produce the same quality music as a high-end facility—no matter where you create it, even if it's a home studio setup.
Music Production  Yaron Fuchs Home Studio Set Up
YARON FUCHS' HOME STUDIO
Get an inside look at Yaron's home studio, where he uses the cloud, records, edits and mixes music.
See his studio >
The Craft
Collaborate. Record. Edit. Mix. Distribute.
With unmatched performance, a Pro Tools system makes any production possible. The only limit is your creativity. No matter where you work with Pro Tools - you can move your music forward as easily as inspiration strikes.
DJ Swivel on Music Production Techniques
BREAKING DOWN THE MIX
Learn some new tips and tricks with
Jordan “DJ Swivel” Young as he breaks down his hit song “Colors.”
Watch the action >
The Solution
Building blocks.
Start with Pro Tools | Ultimate. Then build up your studio by adding DSP acceleration, I/O, and control surface. With software and hardware made to work together, you get guaranteed performance, rock solid reliability, and instant access to the tools you need. For all the music you make—wherever you make it.
Andrew Scheps and Avid S1 Control
In-the-box music mixing with Andrew Scheps
Learn how Andrew uses his Pro Tools and Avid S1 setup—in the studio and on the go.
Check it out >
Avid Pro Tools UI
The ultimate foundation.
From idea to final mix, Pro Tools | Ultimate is your music studio’s foundation. And because it's the preferred platform used by studios all over the world, you have full compatibility and continuity wherever you make music.
Find out more about how to take your sound further >
Get Pro Tools | Ultimate >
Uncompromising performance.
The HDX Engine is built to perform. 18 DSP processing cores. Up to 768 voices. 0.7ms latency. Up to 192 channels of I/O. And it’s Thunderbolt 3TM compatible. With this power you can record and mix any production. And have the creative freedom to track through the AAX DSP plugins you want, when you want.
Learn how HDX powers your studio >
DigiLink  DigiSerial 852x532
Avid I_O Systems
I/O. Assemble.
Pro Tools systems are customizable and expandable. With a wide range of interfaces and connectivity options, you can assemble your ideal configuration. Designed for the highest sound quality, to be flexible for any workflow, and adaptable to your needs.
Compare I/O systems >
Learn more about the new MTRX Studio >
Your turnkey studio.
Take the guesswork out of your system setup and get everything you need in one easy bundle—Pro Tools | Ultimate software, HDX card, ThunderboltTM 3 Chassis (desktop or rackmount), and a premium audio interface.
What you need to know about HDX TB 3 Systems >
HDX Bundle 852x523 v2
Avid Control Surface
Mix big in any size space.
Rich visual feedback. Deep software integration. Avid control surfaces let you work fast and creatively, with unparalleled control at your fingertips.
Get to know the Avid S1 >
Find your Avid control surface >
Collaborate with anyone. Anywhere.
Find, connect with, and invite others to collaborate with you, using the free Avid Link app. With Pro Tools Cloud Collaboration, you get high-performance and highly secure private cloud storage to create and produce music with anyone. At any location.
Start Collaborating >
Avid Link
Avid Play
Distribute your music. Everywhere.
With AvidPlay you can release your music around the world to over 150 major streaming services like Spotify, Apple Music, Tik Tok, Amazon Music, and Tidal. Plus, keep 100% of your rights and earnings.
Get Played. Get Paid >
Build your studio
Start building your custom, integrated studio today.
Contact sales
or
Find a reseller
