JUNE 24, 2021
HDX Hybrid Engine
The Hybrid Engine is now available for HDX Systems. This intelligent hardware-software integration, which was introduced along with Pro Tools | Carbon, lets you move seamlessly between DSP and native processing at the touch of a button.
So, you might wonder, since HDX Systems are well known to handle the most demanding sessions in both music and audio post production, why is the Hybrid Engine such a game-changer? And as a current HDX user, why do I need it? Here are a few compelling reasons why.
Maximize Pro Tools Performance
Without the Hybrid Engine, HDX does the heavy lifting for mixer functions and DSP tasks. Apart from native plugins, which run on your host computer, your entire Pro Tools session is handled by its 18 DSP cores and two high-performance FPGA chips.
The power of HDX is that it essentially eliminates recording latency—sub-1 ms—and delivers deterministic, reliable performance. No system does this better. But "determinism" also means a hard and fast voice limit that puts a cap on session size. For users that work with high track counts and plugin-heavy sessions, like big Dolby Atmos mixes, this can be constraining. Also, HDX can be inefficient when using native and DSP plugins on the same track. For example, inserting a native plugin after a DSP plugin causes round-tripping between HDX and your host computer that eats into available voices.
HDX Systems versus HDX Hybrid Engine
By contrast, the Hybrid Engine splits processing between DSP and native mix engines. It runs your session on your host computer, taking advantage of its robust computing power. Then, when you need to supplement your CPU or record with near-zero latency, it gives you immediate access to HDX’s onboard DSP.
The result is a significant boost to performance. The Hybrid Engine enables you to run bigger sessions more smoothly because it can use native and DSP voices at the same time. It also eliminates round-tripping when using native and DSP plugins on the same track. This has the added benefit of reducing system delay, which directly improves the fader and knob responsiveness of a control surface. And with these powerful new capabilities, when you upgrade your computer, you'll be able to realize its full power and still get HDX's unique capabilities on demand when you need them.
Performance is on a different planet. You get the power and flexibility of native processing with all the benefits of HDX when you need it—massive I/O, frame edge sync, and high-performance DSP on demand.
Jonathan Wales, Award-Winning Re-Recording Mixer, Get OutMementoGaga: Five Foot Two, and The Haunting of Hill House
HDX Hybrid Engine
Do Way More with Just One HDX Card
Without the Hybrid Engine, HDX is limited by a maximum number of voices—256 per card—which puts an upper bound on session size. In audio post production, where massive mixes are commonplace, this presents a big challenge. Even with three cards and 768 voices, DSP headroom can evaporate fast amid hundreds of mono tracks, surround tracks, and plugins.
The Hybrid Engine overcomes this challenge by letting you work with thousands of native voices alongside HDX's onboard DSP. With the June 2021 release of Pro Tools | Ultimate, the native voice limit increases to 2048 at all sample rates—over twice as many as a typical three-card system. This means that all HDX configurations—including single-card HDX Systems like the HDX Thunderbolt 3 MTRX Studio Bundle—now have the same, incredibly high voice limit.
As a result, smaller, streamlined systems will be able to take on bigger sessions with greater ease. Home studios will be able to do more with just a one-card system, and major facilities will be able to keep costs low.
I couldn't possibly mix on any other platform than the HDX cards with the Hybrid Engine. It's the most efficient Pro Tools system that exists. Period.
Andrew Scheps, Mixing Engineer, Producer (Adele, Red Hot Chili Peppers, Metallica)
Pro Tools with HDX Hybrid Engine
Near-Zero Latency at the Touch of a Button
Recording latency can make you feel like you're playing out of sync with the session. As an artist, it can disconnect you from the creative moment. As an engineer, it can disrupt the recording process.
The Hybrid Engine lets you nullify the distracting effects of latency by clicking a button. When you put a track in DSP Mode, its entire signal chain and AAX DSP-compatible plugins are processed directly on the HDX card while your host computer plays back the rest of your mix. When you toggle it off, the track reverts to Native Mode. With this intelligent integration built into Pro Tools, you can move effortlessly between tracking and mixing, without the hassle of latency.
What Our Users Are Saying
The Hybrid Engine is already transforming the way HDX users record and mix the most demanding Pro Tools sessions in both music and audio post production. For users who got an early look at the HDX Hybrid Engine, it’s become invaluable. Here’s what they have to say about it:
The Hybrid Engine is a total game changer for HDX! The improvements in performance are mind boggling. In my opinion, this is the most important and innovative advancement for Avid in 10 years.
Ron Aston, Sound Designer/Sound Effects Editor
It's now clear that the Hybrid Engine with HDX is the most powerful Pro Tools system ever. Game changer for real!
Pino Pischetola, Mixing Engineer, Pinaxa Studio
With the Hybrid Engine, I have all the best advantages of a native engine while leveraging the real-time power of HDX.
Brandon Howlett, Re-Recording Engineer, Vibe Audio Post
The Hybrid Engine allowed me to expand my mixing template and increase my CPU headroom while reducing overall mixer latency. In fact, I cannot run sessions based on my updated template under the legacy HDX Engine, but they run amazingly smooth with the Hybrid Engine enabled.
Ben Eggehorn, Producer, Engineer, Mixer
To learn more about HDX, visit avid.com/hdx and read our FAQ.
Discover Hdx
  • As Pro Audio Market Solutions Manager, I focus on delivering the best creative solutions for music and audio post. I am passionate about creativity and technology with regard to music, songwriting/storytelling, and the recording arts.
