Collage of various user interfaces
Get access to a curated collection of free plugins, music & sound libraries, training resources, and more by the most innovative partner brands with your annual Pro Tools subscription or perpetual license with active upgrade plan. Claim over $3,500 in free products and special offers—see how to claim the rewards in Pro Tools 2025.10 and later here and this video for all other rewards.
Got a subscription or support plan?
Get your rewards
Not a subscriber?
Get Pro Tools
Got a perpetual license without a support plan?
Get current
FREE PLUGINS, MUSIC & SOUND LIBRARIES, AND TRAINING
Not trials or subscriptions—these are all yours to keep, explore, and create with.
  • Ampknob
    BOGREN DIGITAL AMPKNOB BDH III
    Ampknob BDH III gives you access to three incarnations of an era-defining high-gain tube guitar amplifier. Work fast and get the album-ready guitar sound you’re after without endless tweaking or second-guessing.
  • Bad Math image
    CUT CLASSIC BAD MATH
    Bad Math is an extreme tone-shaping tool that blends multiband fuzz and overdrive into a uniquely destructive creative weapon. Built around an 8-band crossover network, each frequency band is run through two custom digital fuzz modes, then recombined and pushed through an additional overdrive stage for extra saturation and edge.
  • Audio Brewers image
    AUDIO BREWERS AB DECODER HOA EXPRESS
    AB Decoder HOA Express lets you quickly translate your Ambisonics signals into Stereo, 5.1, or even 7.1.2 beds with no configuration required. The entire process is automatic and designed to deliver instant, reliable results.
  • Axart Labs image
    AXART LABS AUTOBEAT LITE
    AutoBeat Lite is an AI-powered, 12-track generative MIDI beat engine that delivers fresh patterns across a range of modern genres. Utilize intuitive musical controls, detailed step editing, and real-time MIDI pattern triggering to quickly shape grooves and refine ideas with precision.
  • Safari Pedals image
    SAFARI PEDALS TIME MACHINE
    Time Machine is a plugin that gives you access to four unique sound "filters" that recreate the iconic tones of the 50s, 60s, 70s, and 80s at the click of a button. Each era is crafted with a tailored combination of filtering, saturation, and compression, along with recorded Lo-Fi noise samples from each time period.
  • Wave Alchemy image
    WAVE ALCHEMY TRIAZ PLAYER + AVID SELECT EXPANSION
    Triaz Player lets you build, shape, and polish drum tracks with ease. The included AAX plugin supports effortless drag-and-drop export of audio or MIDI into your session and this edition also includes Avid Select—180 signature presets curated from Wave Alchemy’s acclaimed expansion catalogue.
  • ACON DIGITAL VERBERATE 2
    Verberate 2 is a transparent reverb that recreates realistic spaces without coloration. With precise shaping tools for damping, modulation, and diffusion, Verberate 2 enhances mixes without masking detail—ideal for music production, post, and real-time environments.
  • ACON DIGITAL DEBLEED:SNARE
    DeBleed:Snare is an advanced AI-powered plugin that lets you quickly and transparently remove unwanted mic bleed from snare drum recordings in real-time to deliver cleaner and more natural drum recordings.
  • NIGHTFOX AUDIO RENDITION LITE
    Rendition Lite is the MIDI chord and arpeggiator plugin that helps artists and producers quickly play chords and ARPs without needing to understand music theory or complicated programming.
  • Pummeled Piano
    PUMMELED PIANO KONTAKT LEAP EXPANSION
    Though famed for melody and harmony, the piano is classified as a percussive instrument because hammers strike its strings to make sound. Pummeled Piano takes a more literal interpretation of percussion, offering a collection percussive loops and cinematic sound FX generated by literally striking a piano in numerous and often cacophonous ways that can be played and tweaked in the Kontakt Leap live looper.
  • Eventide Drums
    EVENTIDE DRUMS KONTAKT LEAP EXPANSION
    Eventide has developed legendary multi-effects processor over the years a highly respected signature sound. While often used for guitar, H90 and H9000 units were used to process a ton of drums and loops that you can trigger using Kontakt Leap.
  • CORE EQ & CORE Compressor from KIT Plugins
    CORE EQ combines the best of both worlds: the precision of modern digital EQ's and the feel of popular analog designs. This versatile tool is perfect for shaping your mix with smooth, clean curves while preserving the original character of your tracks. CORE Compressor blends digital precision with analog warmth to give you dynamic tonal control over your mix. This plugin features a ‘Body’ knob for adding depth and richness to your sound, along with a ‘Crush’ button for aggressive compression when you need it.
  • Process Audio Spicerack
    The Spicerack plugin delivers five distinct distortion types, making it the ultimate tool for adding warmth and grit to your mixes and elevate your productions.
    Whether you're shaping vocals, enhancing drums, or experimenting with unique textures, Spicerack provides the versatility and power you need to transform your sound.
  • BST100 V2 Super Overdrive
    BST100 V2 Super Overdrive is a high-gain guitar amplifier plugin with rich harmonics and versatile tone shaping parameters and modern tools to help you create the most extreme guitar tones.
    But this plugin isn’t just an amp—it’s an entire recording studio experience, letting you blend, mix, and create with eight different guitar cabinets and four mic emulations, plus control for on/off position switch, distance knobs, filters, a mixer section, and more.
  • Handy Drums Studio Standard
    Handy Drums Studio Standard by GoranGrooves is an award-winning drum machine with meticulously produced acoustic drum samples and an ultra-refined workflow.
    Forget fiddling with mic blends or phase alignment—get the “album-ready” sound right out of the box. Produce pop, rock, country, blues, or jazz with the legendary warmth and punch of a Yamaha Maple Custom drum set with Zildjian A-custom cymbals. Find expertly recorded percussion hits like congas, bongos, timbales, shakers, maracas, and more.
  • T-Compressor
    T-Compressor by Techivation is not your average compressor, allowing you to layer up to three rounds of compression within a single plugin instance.
    Control up to three of four compression styles (clean, crispy, warm, and thick) in a single plugin window to uniquely shape and color the character of your sound. Try combining clean, warm, and crispy flavors together on vocals. Or maybe mix clean and thick on a kick. The possibilities are endless.
  • Mixup.Audio
    Mixup.Audio is the ultimate collaboration tool for giving and receiving feedback on music—and it has a few tricks up its sleeve.
    Share your projects and mixes with anyone with a single link—no login required. Give feedback at specific points in the session. Compare versions of your mix, no matter how many it takes. Approve or disapprove changes. Never bother with email or text chains for session notes again.
  • Soundsnap
    Soundsnap is the world’s largest and most popular professional SFX library with over 465,000 sounds and more added weekly.
    Find sounds spanning industrial impacts, ethereal ambiences, science fiction foley, and more. Choose from categories like collide, steel, futuristic, crash, wood, and more. Perfect for sound and game designers, music producers, and everything in between. All royalty-free.
  • UJAM Beatmaker DOPE
    UJAM’s Beatmaker DOPE is a virtual instrument that puts all kinds of percussion spanning hip hop styles, eras, and textures at your fingertips for quick creation.
    Choose from over 50 different styles and over 1,000 rhythmical phrases for instant song intros, fills, verses, choruses, breakdowns, and endings. And take total creative control of your textures with creative parameters like filters, vinyl drive, distortion, saturation, ambience, and more.
  • Rob Papen Predator-3 PL
    Predator-3 PL is a powerful hybrid analog and wavetable synth and the secret weapon for any producer or songwriter looking to quickly find sounds and inspiration.
    Packing 5,200+ presets, plus essential parameters like analog-modeled filters, pitch bend control, and more, it’s easy to find and dial-in the sound you’re looking for to add extra spice to your production. Or explore and discover something totally new and different.
  • Plugin Alliance
    Pick Your Favorite from Plugin Alliance
    Plugin Alliance is a curated marketplace with hundreds of plugins from some of the industry’s most advanced and in-demand developers, including Solid State Logic, Brainworx, Shadow Hills, Mäag Audio, SPL, and more. For this reward, pick any plugin from a select list of plugins from Plugin Alliance, and it’s yours to keep.
  • PSP oldTimer
    PSP oldTimer is an easy-to-use vintage-style compressor plugin that gives you the power and versatility to enhance tracks with soft, smooth compression at low levels, or color your audio with the sound of tube emulation when pushed to extremes.
    With just a few clicks, you can dial-in an analog pumping effect without the grit and loss of high end. Or quickly add coloration that smooths but doesn’t dull. Plus, with its zero-latency processing, you can bring a vintage vibe to all your live applications—monitoring, broadcasting, and managing levels while tracking.
  • LANDR Studio + LANDR FX Bass
    Get a free 2-month All-Access Pass to the best LANDR has to offer. Create music with exclusive sample libraries and plugins. Master tracks with intelligent AI. And collaborate over high-quality video. Plus, get LANDR FX Bass—a single-knob plugin with over 40 presets to shape and dial-in the bass effects you desire—for free.
  • INSPIRATA Lite
    INSPIRATA Lite is an easy-to-use stereo convolution reverb plugin that puts ultra-realistic emulations of a wide variety of real acoustic spaces from around the world at your fingertips.
    With just a few clicks, you can make your mix sound like it was actually recorded in the space you choose—from small rooms to iconic concert halls and churches. Then fine-tune the listener’s position, acoustic reflections, stereo width, and more. With INSPIRATA Lite, you can have any acoustic space all to yourself.
  • Antares Duo
    From the makers of Auto-Tune, Duo is a professional vocal plugin that makes it easy to enhance your vocal productions by automatically generating doubled vocal parts from an existing single vocal.
    Add weight, presence, and character to your vocals with just a few clicks. With programmable variations in pitch, timing, vibrato depth, and vocal timbre, it’s easy to create a doubled part that sounds like the same person as the lead vocal—or like someone else entirely.
  • Rift Filter Lite
    Experience a whole new approach to filter design and take your sounds to the next level. Choose from 24 state-of-the-art filters and manipulate them like never before. Explore new types of morphing, vowel, phaser, peaking, and more filters.
    Then transform your sounds with precision. Sculpt jaw-dropping movement with morph and stereo spread controls. Plus, intuitive pitch snapping, pitch snap scales, and MIDI tracking make Minimal Audio’s Rift Filter Lite the most flexible filter on the market.
  • Odyssey
    The Odyssey Collection: Design Elements
    Sweeten and add texture to your sound design with The Odyssey Collection: Design Elements (ODE)—your go-to versatile sound design elements library created to enhance any audio post project from film, television, trailers, and games to advertising, podcasts, web, and beyond.
    Created in collaboration with Academy Award®-winning sound artists Mark Mangini (Mad Max: Fury Road) and Richard L. Anderson (Raiders of the Lost Ark), ODE includes expertly crafted hits, transitions, whooshes, and other vital design elements and layers that you can consistently rely on to finish projects faster and more creatively.
  • Comeback Kid
    Have sounds return as better versions of themselves—loaded with character and analog flavor.
    The effect’s layout is inspired by the creative workflow of hardware. There are no sub-menus or hidden features. Just an ultra-flexible delay engine, along with 14 “flavor knobs” to add sonic goodness to your wet signal.
  • AmpliTube 5 SE
    • The leading amp and effects plugin with 77 models of must-have gear
    • Includes stomps, amps, cabs, speakers, mics, rooms, and rack FX
    • Drag and drop signal chain supports up to 57 simultaneous models
    • Ultra-realistic VIR™ technology dramatically improves all cab models
    • Mixer section to blend multiple cabs, mics, and DI with 19 mixing effects
  • Pro Sound Effects
    Pro Sound Effects creates sound effects libraries and software developed with award-winning sound artists and world-class recordists.
    For sound editors: Bring scenes to life with Foley Essentials - featuring lifelike recordings of everyday actions and props curated from Academy Award®-winners Mark Mangini & Richard L. Anderson.
    For music producers: Find fresh ideas with Producer's Pack Vol. 1 - featuring rare samples selected from unique source recordings and edited into oneshots and loops.
  • Convology
    Convology XT
    Create natural-sounding spaces with this high-quality, easy-to-use convolution reverb, which includes 70 vintage reverb impulse response files from all over the world.
    For Pro Tools subscribers, Impulse Record has also included 17 Physical Plates, sampled in seven different countries, for free.
  • Groove3
    Groove3
    Improve your mixing, production, and software skills with 3 credits to use on Groove3.com.
    Choose from a large assortment of video tutorials and books available for streaming and download, covering a wide range of topics. And get priceless tips from such greats as Quincy Jones and Bruce Swedien.
  • EQuivocate
    Perfect for mixing and mastering, EQuivocate's auditory filters and match EQ functionality make it incredibly powerful, simple to use, and natural sounding.
    EQuivocate uses filters that are modeled on the human ear, making any combination of settings sound as natural and transparent as possible. And with its Match EQ feature, you can make the sound of your track match or complement the audio signal streamed to its sidechain. Even use it to make a final master match the tone of a reference track or help fit a sound into a dense mix.
  • Sound Credit
    Capture credits in the moment, then edit and deliver them to clients or publish online.
    With the Publisher desktop app, you can review, add, and edit music credits, then deliver them to clients and labels. With the Tracker plug-in, you can capture and track complete credits and production details during recording sessions.
  • Sound Ideas
    Sound Ideas
    Get 50 professional, high-quality production music tracks for your projects from Sound Ideas.
    This royalty-free music library allows you to use these tracks on any project, as the music comes with a worldwide license, so you never have to worry about where in the world your production may be watched or used.
  • pureMix
    pureMix
    Get the five most popular pureMix.net tutorials for FREE just for being an annual Pro Tools subscriber.
    Learn how to produce a beat using virtual instruments, record vocals with confidence, add EQ to make your vocals shine, compress tracks for loudness and dynamics, and dial in a radio-ready mix.
AVID DISCOUNTS
Expand your creative capabilities and purchasing power with these awesome deals.
AvidPlay Music Distribution Deal for Pro Tools
AvidPlay Unlimited Stereo Music Distribution
Get your music on 150+ streaming services all over the world—from Spotify and Apple Music to TikTok, Instagram, and more.
Disclaimer: These free plugins, music & sound libraries, tutorials, and other resources are available only to annual Pro Tools Artist, Pro Tools Studio, Pro Tools Ultimate, Pro Tools Studio for Education, and Pro Tools Ultimate for Education (“paid monthly” and “paid upfront”) subscribers, as well as Pro Tools Studio and Pro Tools Ultimate perpetual license owners with an active Software Updates + Support Plan, and can be claimed through your Avid Account or in Avid Link.
The following are NOT ELIGIBLE to receive these free rewards and offers: Pro Tools Artist, Pro Tools Studio, and Pro Tools Ultimate month-to-month subscriptions, Avid Learning Partners, and Pro Tools Studio and Pro Tools Ultimate multi-seat licenses.
