APRIL 28, 2026
PRO TOOLS INNER CIRCLE REWARD: BAD MATH—BUILT TO BE BROKEN, DESIGNED FOR EXPLORATION
Bad Math delivers something most plugins won’t: deliberate mathematical imperfection. The whole idea behind it is using intentionally unconventional distortion algorithms for tone shaping, and the results end up doing things that are genuinely hard to find anywhere else. It can be subtle, shaping the character of a sound without announcing itself. Or it can completely transform a source into something new. Best of all, Bad Math is available free as an Inner Circle Reward to all Pro Tools Artist, Studio, and Ultimate customers with active annual subscriptions and perpetual upgrade plans.
If you’re new to Pro Tools, you can learn more and download the free 30-day trial here.
Built around an 8-band multiband fuzz architecture, Bad Math takes lo-fi, mathematically “wrong” distortion and turns it into a powerful tool for texture, saturation, and sonic destruction. It works on any source material, rewards experimentation, and brings a raw, expressive quality to modern production that cleaner tools simply don’t even try to replicate.
Built for producers and music creators of all kinds, Bad Math offers a genuinely different approach to distortion and overdrive.
WHAT’S INSIDE
An 8-band fuzz engine that runs your signal through intentional mathematical error, with results that can go from surprisingly musical to completely unhinged depending on how you push it.
The Multiband Architecture
At the heart of Bad Math is an 8-band crossover network. Rather than processing your signal as a single entity, Bad Math splits it into eight independent frequency bands, runs each through its own fuzz circuit, then recombines them and passes the result through a final overdrive stage.
This architecture gives producers precise tonal control beyond a typical distortion plugin. The low end saturates differently from the high mids. The highs can be pushed to the edge while the fundamental of a bass note stays intact. Each band has 32dB of gain available, with an additional 100dB of fuzz on top, more than enough to push any signal into the extremes.
The Tone slider functions like a tone pot applied to each individual band, giving you a fast and intuitive way to shape brightness and weight across the entire frequency range without diving into individual band settings.
Two Fuzz Modes Per Band
Each of the eight bands offers two distinct fuzz modes. Angry is a primitive digital fuzz algorithm, raw and direct. Dead is a more extreme experimental signal mangling distortion, pushing the digital signal into genuinely unpredictable territory.
Switching between these two modes is a significant tonal shift. Angry is aggressive but controlled. Dead is chaotic.
Drive and Final Clip Stage
The Drive control sits before the final clipping stage, allowing you to shape how hard the signal hits the output clipper. Back it off for warmth and color; push it for saturation and commitment. It is a simple control with a wide range of outcomes depending on how it interacts with your band settings.
SNAPSHOT BLEND
Bad Math replaces the standard A/B compare found in most plugins with a Snapshot Blend system. Capture two states of the plugin and use a single control to morph smoothly between them. This makes it easy to find the precise balance between a subtle tone-shaping setting and something more aggressive, without rebuilding your settings manually.
Snapshot Blend is useful for sound design, mixing, and any situation where you want to explore the space between two tonal extremes.
OVERSAMPLING AND QUALITY SETTINGS
Bad Math includes five oversampling modes. One minimum-phase mode for zero-latency processing, three classic linear-phase modes with different filter steepness settings, and a special FFT mode that delivers extreme fidelity at the cost of increased latency.
Real-time processing supports up to 16x oversampling. For the linear phase and FFT modes, offline rendering extends that up to 64x. The effective sample rate is always displayed in the plugin menu.
WHAT BAD MATH IS FOR
Bad Math works well across a wide range of sources and workflows, including:
  • Producers looking for fuzz, saturation, and texture tools that go beyond standard overdrive
  • Sound designers who want multiband distortion for detailed frequency-specific processing
  • Composers and editors working in experimental or lo-fi contexts who need a destructive tool that stays musically useful
  • Electronic musicians who want to add grit, instability, and character to synths, drums, and basses
  • Any creator who has wanted to do something with distortion that conventional plugins won’t allow
Bad Math is equally useful for subtle tone shaping at low settings and complete sonic transformation at high ones.
DEVELOPMENT LAB
Bad Math is the first release from Cut Classic’s Development Lab, a line of focused, single-function plugins built around experimental DSP ideas. We launched our first product, High Flyer, less than a year ago exclusively with Plugin Alliance. Bad Math represents the next step: a plugin that came out of a period of heads-down building, where the goal was to push further.
Development Lab plugins are designed to be lightweight and affordable, with no unnecessary features and no compromises on the core concept. They are tools for creative exploration: audio Skunk Works, built for producers who want to push beyond what standard processing can do.
TECHNICAL SPECIFICATIONS
Supported Plugin Formats: AAX Native, AU, VST3
Supported Operating Systems: macOS 12 and higher Windows 10 and higher
Mac: Intel or Apple Silicon
PC: x64-compatible CPU
Display: 1440 x 900px or 1280 x 960px or higher
Learn more about Cut Classic and Bad Math at cutclassic.com.
AVAILABILITY
Cut Classic Bad Math is available to all Pro Tools Artist, Studio, and Ultimate customers with active annual subscriptions and perpetual upgrade plans. You can download the plugin through Avid Link or from your Avid Account.
