Remove hum, clicks, and echoes in your Pro Tools® session with integrated tools for noise reduction and restoration. Use Strip Silence for quick cleanup and ARA-powered spectral repair from partners like iZotope and Steinberg to achieve a clear, natural sound without ever leaving your workflow.
Powerful Tools for Cleaner Audio
Strip Silence for instant cleanup
Automatically detect and remove low-level noise and silence between phrases, giving you a clean starting point for dialogue, VO, and music editing.
Remove unwanted noise
Use the iZotope RX Spectral Editor to remove clicks, hum, and background noise from your recordings directly in Pro Tools for faster, seamless cleanup.
Visually isolate and refine your sound
See your audio in layers with SpectraLayers Go via ARA 2 to extract vocals, separate elements, and clean or rebalance your mix right inside Pro Tools.
resources
How to remove background noise from audio
Step-by-step tips for cleaning up your recordings in Pro Tools.
How to edit audio: Guide to a polished sound
Explore techniques for cleaning, aligning, and enhancing audio.
Audio gain staging guide
Learn how proper gain staging keeps your mix clean and distortion-free.
Remove noise. Keep the performance.
Get Pro Tools and remove background noise fast with built-in and integrated tools.
