JULY 1, 2026
Top 5 reasons Avid NEXIS is the choice for modern media production
When evaluating storage for professional media environments, the stakes are high. Ensuring your teams can create, collaborate, and deliver under real-world pressure takes more than capacity.
For broadcasters, post-production facilities, and large creative teams, Avid NEXIS consistently stands out as a platform built specifically for these demands.
1. Performance that holds up under pressure
Whether you have a handful of editors or hundreds working simultaneously, the Avid NEXIS system intelligently manages bandwidth so everyone gets the performance they need—even when accessing the same media at the same time.
Avid NEXIS is engineered for one thing above all: predictable performance in real production environments. No dropped frames, no slowdowns, and no last-minute surprises when deadlines matter most.
The numbers back it up. At full scale, Avid NEXIS can deliver over 30 GB/s of bandwidth across a single system, enough to simultaneously stream more than 680 channels of DNxHD or 250 streams of Sony XAVC-Intra UHD content. That's not just a lab benchmark: it's the same infrastructure trusted across more than 3,000 production environments worldwide, including 8K HDR productions. For Kansai Television’s short film Three Trees, director/editor/colorist Kazuma Yano relied on Media Composer from end to end to bring an 8K HDR workflow to life, demonstrating the kind of demanding, high-resolution production environments Avid workflows support.
Get in touch
Speak with a workflow consultant about Avid NEXIS.
Contact us
2. Application integration that just works
With deep integration into Avid Media Composer and Avid MediaCentral, Avid NEXIS enables native collaboration through shared projects, bin locking, and real-time access to media.
Most storage systems treat Media Composer like any other application—they hold the files, and that’s it. Avid NEXIS is different because Media Composer and NEXIS function as one, with media delivery and the application working in unison to deliver unmatched performance at scale.
Editors don’t need to think about where files are or whether systems are in sync. Everything is connected, reducing friction and keeping teams focused on creative work. And with the arrival of Avid Content Core, tight integration between storage and application is ready to be a foundation for a new era of storage intelligence.
In practice today, that means a lead editor, two assistants, and a producer can all be inside the same project working in their own sequences, accessing the same high-resolution media, with no copying, no syncing, and no version conflicts. The team can move much faster, with fewer mistakes, trusting the infrastructure to keep everyone in sync.
Bin locking is at the heart of this: when an editor opens a bin, NEXIS marks it so no one else can accidentally overwrite it. Colleagues can still open it in read-only mode to reference or pull clips—they just can't write to it until the lock is released. It's a simple concept that eliminates one of the most common and costly mistakes in collaborative post-production.
3. Resilience you can rely on
In environments where content must go to air—or deadlines are immovable—resilience is non-negotiable.
Avid NEXIS is built with multiple layers of fault tolerance, so a single failure doesn’t have to become a production outage. At the storage level, you can choose the protection that fits the risk profile of your workflow: mirroring, single-disk protection, or dual-disk protection.
With full mirroring, your media exists in two fully up-to-date copies, so the system can continue serving content even if an entire storage engine is lost. For example, if a storage engine experiences a fault or has to be taken out of service unexpectedly, clients can keep reading and writing against the mirrored copy, so editors aren’t suddenly kicked out of the timeline, exports don’t stall mid delivery, and producers don’t lose access while hardware is recovered.
With single-disk protection, NEXIS is designed to keep workspaces online through a drive failure while the system rebuilds in the background. With dual-disk protection, that safety net extends to two simultaneous drive failures—an added margin for large-capacity systems where rebuilds take longer and the operational cost of downtime is highest. All of this is easily managed and configured in software.
Resilience also extends beyond disks. Hardware components can and do fail—power supplies, controllers, network paths—but NEXIS is designed so that the system keeps running. If a power supply fails, there’s a spare. If a network link or switch path drops, redundant networking keeps clients connected. The result: editors stay in the timeline, assistants keep turning over media, and producers aren’t forced into expensive stop and start workarounds while the storage team scrambles to restore access.
Because when storage goes offline, the cost isn’t measured only in minutes, it’s measured in missed air windows, delayed deliveries, overtime, and entire teams waiting for access. Downtime is one of those risks you only fully understand the day it happens.
4. Hybrid flexibility for modern workloads
Production is no longer confined to a single building.
Avid NEXIS offers a unified file system that can be deployed on-premises, in the cloud, or across both. Teams access the same workflows through a consistent client experience, regardless of location.
  • Cloud deployments enable remote collaboration today
  • Additional capacity can be spun up in minutes when needed
  • On-premises remote access capabilities are evolving to extend this flexibility further
This ensures your infrastructure adapts as your workflows evolve without disruption.
“There's no better shared ecosystem than Avid and NEXIS. Just having a rock-solid, stable system that we could count on to not crash, and where it's easy to pass things off between each other was really, really critical for us. Even working remotely, we were able to collaborate perfectly seamlessly the whole time.”
Evan Wise, Supervising Editor, Chimp Crazy
5. Simplicity that scales with your operation
As environments grow, complexity can quickly become a barrier. Avid NEXIS is designed to stay simple for users and administrators.
For editors:
  • Access media through intuitive “workspaces” that behave like virtual drives
  • Start working immediately with minimal training
For administrators:
  • Add storage engines without downtime to increase bandwidth and capacity
  • Manage users and permissions through a straightforward web-based interface
  • Quickly assign user and group access to workspaces
With FlexDrive, storage becomes dynamic:
  • Resize workspaces instantly—no downtime or disruption
  • Reallocate capacity on demand as projects change
  • Keep utilization efficient without complex reconfiguration
The result is a system that’s easy to manage day-to-day, even at enterprise scale.
Final thoughts
Choosing the right storage platform has a direct impact on how efficiently your teams work and how reliably you deliver content.
NEXIS is purpose-built media storage that goes above and beyond what general-purpose infrastructure delivers. The difference shows up fastest when you look at the alternative: best-effort performance, bolt-on collaboration, and workarounds that cost time (and sometimes deliveries) when pressure is highest.
For organizations that need their infrastructure to perform as reliably as their teams, Avid NEXIS is the solution built for the realities of modern media production.
