EUCON 2026.11 NOW AVAILABLE—WHAT’S NEW
EUCON 2026.11 is a feature release for Avid control surfaces. All EUCON surfaces gain Custom Insert Maps in the EQ and DYN functions, so channel strip and modern EQ/dynamics plugins get full parameter access with graphs and color coding. EUCON 2026.11 also introduces the new EUCON MeterView App for Avid S4 and S6 surfaces, which mirrors Master and Post Meter displays on a Mac or PC, including an extended –90 dB meter range.
See the What's New Guides for the full list.
If you have a current software support contract for S4 or S6, go to your Avid Account to download, or go here for EuControl software for other EUCON surfaces.
EUCONTROL SURFACE ENHANCEMENTS
Custom Insert Maps in EQ and DYN
- Use Custom Insert Maps directly in the EQ and DYN functions on S1, S3, Dock, Artist Series and Avid Control. You get every mapped plugin parameter plus EQ/Dynamics graphs, page cycling, and magenta (EQ) and green (Dynamics) color coding.
- Create dedicated Custom Insert EQ and Custom Insert DYN maps—ideal for channel strip plugins that combine both.
- The new feature is added to EuControl > General > EQ/DYN Custom Insert Maps: None, Insert Function, or EQ/DYN Functions.
Avid Control
• Basic and Routing Folder Tracks now appear as separate categories on the Tracks page for more granular selection.
AVID S4/S6 ENHANCEMENTS
- EUCON MeterView App – Mirror Master and Post Meter displays on a separate Mac or Windows computer on the same EUCON network. Run up to four instances, each assigned to its own display. Included in the workstation installers
- Custom Insert EQ and DYN Maps – Use custom Insert maps directly in the EQ and DYN functions, with graphs, function colors and cycling. Enable Use Custom Insert Maps on EQ and Dyn Functions in Settings > User > Knobs.
- Updated Meter Range – The Digital VU meter now extends to –90 dB only on the S4 and S6 surfaces.
Note that EQ/DYN functionality and the MeterView app in EUCON 2026.11 both require Pro Tools 2026.11 or later. For compatibility with other DAWs, see the EUCON Compatibility article.
