OCTOBER 18, 2024
STEINBERG SPECTRALAYERS ARA 2 SUPPORT
Steinberg SpectraLayers is an award-winning industry leader in spectral audio editing, audio unmixing, and sound design applications, and the Pro Tools 2024.10 software release delivers seamless ARA 2 support for this powerful solution. With more than a decade of intensive development, SpectraLayers offers an incomparable combination of manual, automatic, and AI-assisted editing tools and processes. SpectraLayers is set apart by the fact that it’s a system, in which advanced algorithms work in tandem with an unparalleled tool set capable of performing extremely precise, non-intrusive and transparent edits.
Pro Tools customers with active subscriptions and perpetual upgrade plans (Pro Tools 2024.10 and later) will also automatically receive the Steinberg SpectraLayers Go ARA plugin.
Explore how to use the Steinberg SpectraLayers Go plugin in Pro Tools:
SpectraLayers empowers editors with precision tools that can operate both globally, and at sample-accurate extremes in the spectrogram. The application features unique and totally remarkable workflows for noise control, rescue and restoration, music and sound unmixing, and freeform creative sound design. Its layer-based approach, similar to image editing applications, enables users to separate audio into discrete and independent layers for editing. The best in AI-assisted processes set the stage for extreme fine tuning using a wide assortment of tools that operate with sample-accurate precision. This audio compositing capability makes SpectraLayers an indispensable solution for professionals seeking complete control and flexibility in the most challenging audio editing scenarios.
In addition to being present as a standalone application at the advent of the spectral audio editing revolution, SpectraLayers was also an early adopter of the ARA protocol. Today, SpectraLayers continuously tracks this exciting breakthrough in application compatibility and workflow efficiency, providing an absolutely seamless workflow in Pro Tools.
SPECTRALAYERS GO ARA PLUGIN FOR PRO TOOLS
SpectraLayers Go is your free gateway to the incredible SpectraLayers experience. Install and launch SpectraLayers Go in Pro Tools and get acquainted with the amazing workflow in our eleventh-generation interface. Visualize audio in a flexible, hyper-detailed spectrogram and explore the concept of layer-based editing. SpectraLayers Go even allows you to extract vocal tracks from music using one of the market’s leading AI-assisted algorithms. The tools in SpectraLayers work together ingeniously to provide an editing experience that is truly remarkable in its ability to shape audio content to achieve seemingly impossible objectives for audio editors in every field. SpectraLayers is essential kit for repair and restoration work, music and post-production mixing and editing, creative sound design, and more.
Benefits of registering SpectraLayers Go
You can start using SpectraLayers Go in Pro Tools right away—no activation needed—but there are additional benefits to registering your product. Simply create a Steinberg account at https://www.steinberg.net/wl-sl-go-upgrade/ and register your copy of SpectraLayers Go. Once registered, you'll receive the following:
  • A license, delivered via email, to launch SpectraLayers Go in standalone mode
  • A discount on the full version of SpectraLayers Pro
  • Access to Steinberg tech support and forums
  • Regular updates on discounts, special offers, and more
Watch this video on how to redeem the SpectraLayers Go plugin and other content in the Pro Tools 2024.10 release:
SPECTRALAYERS: THE VANGUARD OF SPECTRAL AUDIO EDITORS
SpectraLayers Pro is the most full-featured edition in the SpectraLayers product line. Here you’ll find the highest concentration of tools and processes, in particular, the AI-assisted unmixing and repair processes that set the stage for subsequent fine-tuning within the application. SpectraLayers Pro provides an inspiring and extremely satisfying editing experience with astonishing accuracy, depth, and detail.
Learn more >
SpectraLayers Pro: top features at a glance
  • Selection and editing tools. Select audio by time and frequency, make selections with brushes and lassos, delete content with a programmable eraser tool, automatically select harmonics in user-defined orders, brush content out of one layer and into another, apply clones, and more. Once selected, the target audio can be processed on the timeline, extracted to new layers, transferred to existing layers, or deleted entirely. Create workflows in which absolutely no content is ever lost, ensuring the most phase coherent end results possible.
  • AI-assisted processes. SpectraLayers uses the most contemporary deep learning algorithms, bundled in Modules that can be flexibly deployed in the application. Trained on tens of thousands of real-world samples, these processes can identify and extract speech (including overlapping speakers on the same layer), musical instruments (up to seven), and noise (noise can even be isolated on its own layer in some cases), in a wide variety of contexts. Once isolated, the content becomes available both within and outside the application.
  • Other processes. New and legacy processes can analyze, modify, and even generate content in a myriad of ways, based on the nature of the content itself (traditional noiseprint-based noise reduction, event detection, source/destination layer modulation), ambiences (reverb reduction, reverb and ambience matching), phase (in particular, spectral M/S decoding, which can deliver full stereo side layers), and more.
  • Batch Processing. All processes can be chained, and the chains can be employed in batch processing operations. During batch processing, new process-generated layers get deposited into their own dedicated folders.
  • Utilities. SpectraLayers Pro features VST3 plug-in processing that can be inserted anywhere in a process chain, even during batch conversions. Enjoy spectral noise, frequency, and transient generators, selection-based gain, normalize, and reverse operations, perform channel remixing, generate and export speech transcriptions in a variety of text formats, and more.
AVAILABILITY
Steinberg SpectraLayers ARA support is available to all Pro Tools customers on version 2024.10 or later software. Pro Tools Artist, Studio, and Ultimate customers with active subscriptions and perpetual upgrade plans will also automatically receive the Steinberg SpectraLayers Go ARA plugin, which can be downloaded through Avid Link or from your Avid Account.
