In this section
MAY 16, 2024
Fundamentals of Audio Equalization (EQ)
Have you ever adjusted the bass or treble in your music player to get the perfect sound? If so, you've already used a basic form of equalization (EQ), a concept that takes on even more depth in audio production. Within a Digital Audio Workstation (DAW), audio equalizers enable surgical sound adjustments, allowing you to make room for various instruments in a mix, create unique sound effects, or polish a track before releasing it.
In this guide we’ll explore the fundamentals of EQ within the context of audio production. To illustrate, we'll use the Channel Strip plugin in Pro Tools, explaining the functions of its controls, the practical uses of its various filters, and how professional audio engineers use them to shape sound. Let's dive in!
Jump to any section:
What is an audio equalizer (EQ)?
EQ, short for equalization in audio, refers to the process of shaping the frequencies of an audio signal. With an EQ, you can use filters to selectively boost or cut specific frequencies to achieve a desired sound. The process of EQ is both a science and an art: careful adjustments can eliminate unwanted noise, add airiness and clarity to vocals, emphasize the thump of a kick drum, or reduce muddiness caused by multiple instruments clashing in the same frequency range. Additionally, EQ can be used for creative effects, such as emulating the distinct sound of a telephone call in vocals. EQ’s versatility is vast and we'll explore its numerous applications in upcoming discussions. For the time being, let’s focus on grasping the basics of this fundamental tool.
The frequency spectrum
To understand equalizers, it helps to understand the audio frequency spectrum. Every sound we hear has its own frequency profile, a unique combination of pitches that our ears and audio equipment can detect within the range of 20 Hz to 20 kHz. EQ allows us to manipulate these frequencies to enhance or reduce different qualities of a sound.
When you’re EQing, you’re essentially adjusting levels at different points across this spectrum. Knowing how to do this effectively means understanding what each frequency range sounds like and how it behaves. For instance, boosting the lows can add bass to a sound, while cutting the highs might take away some unwanted hiss or harsh sounds.
EQ frequency ranges
The frequency spectrum is divided into distinct bands, each with its own character and influence on the overall sound. By understanding these frequency bands, you’ll be able to identify how you want to shape your sound and what frequencies to focus on to achieve a desired result. Let’s explore the qualities of each frequency band:
  • Low Frequencies: 20 Hz to 250 Hz
  • Low Mids: 250 Hz to 500 Hz
  • Mids: 500 Hz to 2 kHz
  • High Mids: 2 kHz to 4 kHz
  • High Frequencies: 4 kHz to 20 kHz
Low frequencies form the foundation of a track, encompassing the sub-bass and bass. They add weight and power to the music, represented by the rumble of a bass drum or the warmth of a bass guitar. EQ adjustments in this range can boost the energy of a track or tame the muddiness that can cloud the mix.
Low mids carry the darker, fuller qualities of the audio spectrum, often containing the lower notes of rhythm instruments and the warmth of the human voice. Adjusting these frequencies can affect the thickness and body of the sound, helping to balance out the “boxiness” that can occur in this range.
Mids are where much of the action happens, full of essential harmonic content. This range dictates the presence and punch of instruments, especially in guitars and vocals. EQ here can sharpen or soften the core attributes of many instruments.
High mids are responsible for clarity and definition. They can bring forward the bite of a guitar, the attack of a snare, or the articulation of a vocal. Tweaking here requires a delicate touch, as boosts can enhance intelligibility, while too much can introduce harshness.
High frequencies cover the air and sparkle of a mix, including the brilliance of cymbals, the shimmer of strings, and the breathiness of vocals. Careful EQ in this band can lift the liveliness of the music or, if reduced, can soften overly bright recordings.
EQ Parameters
Now that you understand what equalizers do let’s explore the various controls you can use in an equalizer plugin to shape the frequency profile of a sound.
Frequency Selection (Freq)
When you select a frequency, you're choosing the specific part of the audio frequency spectrum you want to manipulate, either by boosting its presence or reducing it to clean up your mix. In the Channel Strip EQ, you'll find four adjustable nodes that let you target frequencies more accurately: the Low Frequency (LF) node (red circle), Low Mid Frequency (LMF) node (orange circle), High Mid Frequency (HMF) node (yellow circle), and the High Frequency (HF) node (blue circle). To adjust a frequency, simply pick one of these nodes and move it to where you feel a boost or cut is needed. This method gives you precise control, whether you're enhancing the warmth of a vocal or making space for your bass to cut through.
Gain
Gain is used to either boost or reduce the level of specific frequency ranges. Boosting the gain increases the volume of a certain frequency band, making it more prominent in the mix. Conversely, reducing the gain, or cutting, lowers the volume of a specific band, helping to remove unwanted frequencies or to balance the overall sound.
Quality factor (Q)
Quality factor, or Q, determines how wide or narrow the range of affected frequencies will be around your selected frequency. A high Q narrows the focus, targeting a tight range of frequencies, perfect for zeroing in on and eliminating pesky problems like unwanted resonance. A lower Q value broadens the impact, affecting a wider frequency range for more general shaping of your sound’s tone.
Filter type
The filter type parameter on an EQ allows you to select the shape and behavior of the filter you're applying to the frequency spectrum. Different filter types include high-pass, low-pass, band-pass, notch, and peaking filters, each designed for specific tasks like removing unwanted frequencies, isolating frequency bands, or gently adjusting the tone of a track. High-pass filters let highs through and cut lows, ideal for removing rumble. Low-pass filters do the opposite, great for taming harshness. Band-pass, notch, and peaking filters can isolate or reduce specific frequency ranges. Picking the appropriate filter type is crucial for sculpting your mix to perfection.
Types of EQ filters
Understanding EQ parameters sets the stage for precision in shaping your sound. However, filter type is one parameter that warrants a closer look due to its influence on the filter’s shape and its impact on frequencies. The choice of filter type can drastically alter the character of your audio, making it a powerful tool in your mixing process.
Each filter type—high-pass, low-pass, band-pass, notch, and peaking—brings a different flavor to your sound and serves a unique purpose. Whether you're cutting out the rumble or sculpting the perfect highs, the right filter can make all the difference. Let's break down these filter types to give you a clearer picture of how to use them effectively in your mixes:
Low pass filters
Low pass filters are designed to allow frequencies below a certain cutoff point to "pass through" unimpeded, while attenuating the frequencies above this point. This results in the removal of high-frequency content, such as harsh sibilance in vocals or the hiss of an overly bright cymbal. It's a go-to tool for adding warmth to a track or ensuring the low-end elements don't get overshadowed by high-frequency noise.
High pass filters
In contrast, High Pass Filters do the exact opposite of their low pass counterparts. They permit high frequencies to cut through while removing lower frequencies. This type of filter is invaluable for eliminating low-end rumble or muddiness from recordings. For instance, it can clean up a vocal track by removing unnecessary low frequencies that may cloud the mix or help a kick drum cut through by focusing on its punchy, high-end attack.
High shelf filters
A high shelf filter affects all frequencies above a certain cutoff frequency by boosting or cutting their amplitude uniformly. This type of filter is useful for enhancing or reducing higher frequency content, such as adding brilliance or reducing harshness in a mix.
Low shelf filter
A low shelf filter operates similarly to a high shelf filter but affects all frequencies below a specified cutoff frequency. It is often used to boost or cut the bass frequencies to add warmth or reduce muddiness in audio tracks. Both high and low shelf filters are valuable tools for shaping the overall tone of a sound in mixing and mastering.
Bell curve
The Bell Curve, or peaking filter, is the most common type of EQ filter. It boosts or cuts a range of frequencies around a central point, creating a bell-shaped curve on the EQ graph. This filter is incredibly versatile—use it to emphasize the snap of a snare, the body of a guitar, or to attenuate a specific range where there might be frequency buildup or feedback.
Notch
The Notch Filter is a precision tool used to eliminate problematic frequencies. It's a narrow and deep cut that can remove unwanted resonances or hums, such as the hum from electrical equipment or a resonant frequency from a recording space. This filter is surgical, targeting and removing specific frequency problems without affecting much of the surrounding audio.
Band-pass
Band-Pass Filters allow a specific range of frequencies to pass through while cutting off both the lower and higher surrounding frequencies. This filter is often used for effects like mimicking a telephone call, where you want to hear only a slice of the frequency spectrum to create a sense of distance or to focus on a particular aspect of the sound.
EQ's role in sound design, mixing, mastering
EQ is an essential tool in audio production and serves different purposes depending on the task. It's the Swiss Army knife in audio production, capable of both subtle adjustments and transformative changes across various stages of production. In each context, EQ serves a specific purpose: crafting new sounds, achieving balance among tracks, or polishing a final mix for the listeners. Let's do a quick overview:
EQ in sound design
In sound design, EQ is an incredibly versatile tool that goes beyond just cleaning up or enhancing audio; it's used to creatively shape sounds to fit a narrative context or to evoke specific atmospheres. For instance, EQ can simulate environments, such as making a sound seem like it's coming from behind a closed door by rolling off high frequencies. The "telephone effect" is another common technique, achieved by using a band-pass filter to mimic the restricted frequency response of an old telephone. Sound designers frequently use EQ to create the illusion of distance or to mimic the acoustics of different spaces, making it an essential element for building immersive audio environments.
EQ in Mixing
During the mixing phase, EQ is primarily used to balance individual tracks within a song. It helps in carving out a unique space for each instrument or vocal part, ensuring that they don't compete for the same frequency range. EQ in mixing can enhance clarity, remove muddiness, and shape the tone of each element so it contributes effectively to the overall mix. It's about creating cohesion among various components, making sure each one can be heard clearly without overpowering the others.
EQ in Mastering
In mastering, EQ takes on a slightly different role. Here, it's used to fine-tune the overall sound of the track or album. The goal is to achieve a balanced frequency response across the entire mix, ensuring it sounds good on all playback systems. Mastering EQ involves subtle adjustments to enhance the mix's overall tone, correct any minor imbalances, and sometimes to ensure consistency across an album.
Start experimenting with EQ
As we've explored, EQ is a fundamental tool in the arsenal of any music producer, essential for shaping and refining the sound of your tracks. From understanding different frequency bands to mastering various EQ parameters and techniques, you now have the foundational knowledge to start shaping your audio with confidence. Remember, the key to effective EQ use is balance and subtlety. It's not just about making individual elements sound good but ensuring they all work together to create a cohesive and harmonious mix. Whether you're boosting to add brilliance or cutting to reduce muddiness, each adjustment should serve the greater goal of enhancing the overall sonic landscape. If you’re just getting started, try experimenting with the premium EQ plugins included in Pro Tools or download Pro Tools Intro for free.
