SEPTEMBER 3, 2026
Film sound workflow secrets revealed
In this series, award-winning film mixer and Avid Audio Specialist Sreejesh Nair (Gangs of Wasseypur, The Legend of Maula Jatt) reveals the complete post-production workflow for film audio, showing both the artistry and the technical processes required for a great mix. See how dialogue, sound effects, foley and music follow their own journeys before coming together for the final mixing and mastering stages.
In this episode we join Sree in the mixing theatre, where he's setting up for the final mix. Sree explains how to configure the Dolby Atmos® renderer to create the final deliverables, and how he sets his console layouts to instantly recall his Pro Tools groups. He also shows how Pro Tools’ integration with SoundFlow allows him to add custom functions and Dolby Atmos® renderer control to the S6 console.
In this episode, Sree works on the final mix and reveals the essential automation methods used by pro film and TV mixers. You’ll learn how to create the foundation of your mix, working in scenes with the Preview and Write workflow. The space of the film is created with panning and reverb. Finally, Sree blends the elements together dynamically with VCA groups ready to be reviewed by the team.
In this episode, Kirk Braganza walks us through a typical workflow for film sound dialogue editing.
Dolby Atmos® Film Mix Template
You can also download Atmos film mix template that Sreejesh Nair works from. 48k/24-bit, 24fps, built around the Pro Tools internal renderer with stem routing, VCA groups and print paths already wired up. The .zip also includes a list of plugins that he uses, and you can see the processing chain as well.
The download also includes the Avid S6 layout XML and which is also embedded in the .ptx session. If you're on an Avid S6 or S4 control surface, you'll get Sree’s worksurface layout, soft key setup and spill arrangement along with the session. You can use this as a starting guide and modify it as you need.
Download now >
Products used:
Pro Tools software
Avid S6
Pro Tools | HDX
Pro Tools | MTRX II interface
Pro Tools | Sync X
If you’re new to Pro Tools, you can learn more and download the free 30-day trial here.
Dolby is a registered trademark of Dolby Laboratories.
