Avid Content Core 2026.11.05 — What’s new?
Last release, Content Core started reacting to events on its own. This release puts that automation in people’s hands too. A new Commands menu lets users run platform actions themselves, starting with sending a notification. Thumbnails extract faster, images open in a new viewer with no download, and the landing page, search, and notifications all fit more closely to the way you work. Additionally, in early access, Content Core gets a native asset store, and organizations can add their own metadata properties and taxonomies so Content Core describes content in the terms your newsroom already uses.
Put the platform to work
The rules engine in the last release lets Content Core act when something happens. This release opens the same automation layer to the people using it and speeds up one of the platform’s heaviest background jobs.
Run actions from the Commands menu
Content Core’s automation layer is made of action engines, each providing a set of actions that administrators configure inside rules. Some of those actions are just as useful in a person’s hands. A new Commands menu entry now offers them directly.
The first command is Notify. Choose one or more users and send them a notification with no rule to set up. The menu is built to grow. Any action designed to run for a user appears there as a command automatically, so new commands can arrive without waiting for new screens.
Thumbnails, faster
Content Core already builds thumbnails ahead of time. Now it builds them faster. Thumbnail extraction is significantly quicker, especially in batch, when Content Core generates every thumbnail for a clip at once. In testing, batch extraction ran up to five times faster. How much quicker it runs for you depends on your infrastructure.
One small improvement while we’re here: the last thumbnail in a segment now shows the segment’s true final frame.
Find it faster
Labels you recognize
Search dropdowns now show taxonomy labels in place of raw values, so you pick from names you know. Properties from different namespaces also appear together in one list, so you don’t need to know where a field lives to search on it.
Favorites, by drag and drop
Drag and drop to add to your Favorites, then switch-on edit mode to tidy them up.
Your landing page, your layout
Put widgets side by side
Last release let you hide, show, and reorder the widgets on your landing page. Now you can place several in a row and size each one to 25, 50, or 75 percent of the width, or drag from its left side to adjust it by hand. Arrange them however suits your day.
Act on several items at once
Select several items on the landing page and the right-click menu now acts on all of them. Send the whole selection straight to the Web Editor in one step.
Notifications on your terms
Pop-up notifications are now grouped by app so you can see at a glance where they’re coming from.
Prefer fewer interruptions? Turn off pop-ups in your user settings, and the Notifications app badge will still show unread notifications so you don’t miss anything.
See more without leaving Content Core
View images in the browser
A new image viewer opens pictures right inside Content Core. Zoom, pan, fit to size, go full screen, rotate, download, or print, with keyboard shortcuts for all of it.
The PDF viewer, in the light theme
The PDF viewer’s header now follows the light theme, so documents sit comfortably alongside the rest of the platform.
For administrators: one way to register a site
The simplified MediaCentral site registration flow introduced earlier this year is now the only one. The previous flow is no longer supported, and the option to copy a JWT token from the Site Registry admin app has been removed with it. If any of your sites were registered the old way, talk to your Customer Success Manager.
In early access: a native asset store
Content Core can now manage assets itself. For the Content Core site, a Native Asset Store is available in early access, so assets can live in Content Core with no MediaCentral connection needed. There’s more to come on this soon.
In early access: describe content in your own terms
Last release moved every taxonomy in Content Core onto a single service and laid the groundwork for organizations to add their own. This release builds on it. Until now, the Global Content Core namespace came with a fixed set of properties. A new Namespace Editor lets workflow administrators add their own alongside them.
Add your own properties
The Namespace Editor shows the predefined properties, which stay read-only next to your custom ones. For each custom property, set its ID, title, data type, and category, decide whether it takes multiple values and how search treats it, and give it a label in each supported language. Several data types are available, including taxonomies of your own.
Build your own taxonomies
The Taxonomy Editor, part of the Namespace Editor, lets you create and edit taxonomy entries as flat lists or trees, and localize each entry. A custom taxonomy can then be the data type for a custom property. Each taxonomy holds up to 30,000 entries and goes up to 10 levels deep. Importing taxonomies is on the roadmap.
Ready the moment you save
Custom properties appear in Search and the Metadata tab as soon as you define them. Any source system can map its own attributes to them when it submits assets through the Content Core API, so the context captured upstream arrives with the asset.
Early access for both the Native Asset Store and custom properties is a controlled rollout to a small number of customers, switched on for each tenant individually. Talk to your Avid account team if you’d like to take part.
Why it matters
Much of this release is about Content Core fitting how you already work: your layout, your favorites, how often you want to be interrupted. Custom properties and taxonomies take that furthest. Every newsroom describes its content its own way, and the context that matters most to you lives in those descriptions. When Content Core can hold your properties and your vocabulary and the systems around it can write to them, that context travels with the content into search, metadata, and everything built on top of them.
The Commands menu points the same way for automation. Actions the platform runs on its own are now within reach of the people who need them, and more will follow.
See the highlights of the Content Core updates all in one place: What's new in Avid Content Core. Or read the full technical release notes for this and all previous releases on the Avid Documentation Center here.
Already running Content Core? Talk to your account manager or Customer Success Manager about putting these updates to work for your team.
