727-Pro Tools header-POST 1920x600
Record, edit, mix, and deliver sound for film, TV, video games, and more with the proven audio production tools professionals have long relied on to do their best work. From ADR and Foley to sound design and Integrated Dolby® Atmos workflows, Pro Tools provides the power and precision you need to create and deliver exceptional work with confidence and ease.
WHAT'S NEW
See what's new in Pro Tools
Pro Tools 2026.4 introduces Track Pin, support for MPEG‑H immersive mixing, Dolby Headphone Personalization, enhanced Speech‑to‑Text workflows, and more.
See what else is new in Pro Tools >
RECORD ADR + FOLEY
  • Replace or add dialogue
    Create flawless ADR and voiceover performances by loop recording your talent in sync with the picture, then comping together the best takes. For ultimate sound quality and sync, add an Avid audio interface or system.
  • Capture Foley performances
    Use blank clips to cue a Foley session quickly and record high-quality sound effects—such as footsteps, rain, punches, and dish rattling—in sync with the movement onscreen to re-produce the sounds of everyday life.
DESIGN, CUT, AND SYNC
  • Create realistic atmospheres
    Design and build up rich sonic elements and ambience that bring life to moving pictures. With up to 2,046 voices/audio tracks and 64 video tracks at your disposal, you can create immersive, unforgettable soundscapes.
  • Design unique sounds and effects
    Create and manipulate sounds for every visual element in a scene—from revving engines to an alien invasion—with over 120 plugins, a huge sound library, Sonic Drop, Melodyne essential, and Elastic Audio to help you sculpt your sonic vision.
  • Edit and position sound
    Work with HD, 4K, and other high-res media directly, enabling you to place and edit sound to picture with great precision and accuracy. From trimming clips and leveraging Clip Effects to positioning elements in 3D audio.
  • Streamline the editorial workflow
    With new Pro tools session compatibility between Pro Tools and Media Composer, you can pick up where the video editor left off to conform sequences. Or sync a session directly with a sequence.
MIX, MONITOR, AND DELIVER
  • Mix the largest sessions with ease
    Get the most advanced automation in the industry to turn around complex productions faster. Handle hundreds of thousands of clips with Folder Tracks. And save tons of time with macros using SoundFlow or create your own with the Scripting SDK.
  • Take control of every element
    Dramatically boost your mixing efficiency and precision with an Avid control surface, which provides unparalleled DAW integration, plus joystick and PEC/Direct options for S4 and S6 to speed up mixing and re-recording tasks.
  • Immerse your audience in sound
    Experience the easiest and most efficient Dolby Atmos, MPEG-HAudio Vivid, and Ambisonics workflows with tightly integrated mixing and monitoring solutions, including the internal Pro Tools Dolby Atmos Renderer.
  • Deliver with confidence
    Pro Tools provides all the technology and workflows you need to meet the technical and delivery specifications required for theatrical release, broadcast, Netflix, streaming, gaming, and other video productions. And new Dropbox Replay integration with Pro Tools gives you a better way to share files, gather feedback, and speed up the review process.
